VCDHelp members/visitors:
I am having a heck of a time trying to burn TSCV 0.72 cue/bin files with any version of NERO (yes, I do have a legal version).
With Nero 5.5.3.5 and earlier, I would get an invalid parameter error in the burn message area 9.9 times out of 10 and then a successful burn. With 5.5.4.0 it reads the TSCV 0.72rel1 bin/cue files as 3 x the actual file size; i.e., 600MB file is read in the nero burn window as 1800MB and naturally says my disk is not big enough. I am pulling my hair out with this bin/cue/NERO problem. Anyone had the same experience and know what I am doing wrong.
system:
Athlon 950
Win98SE
TSCV 0.72 rel 1
Sony CRX140E CDRW
Nero 5.5.4.0
VCDimager 0.7.10Prev4
Any ideas/help would be appreciated
Dave, ARS k5oz
<font size=-1>[ This Message was edited by: k5oz on 2001-08-28 17:45:03 ]</font>
<font size=-1>[ This Message was edited by: k5oz on 2001-08-28 17:46:13 ]</font>
I assume this is due to nero not understanding the complete .cue syntax...
try removing all INDEX lines except for the ones starting as INDEX 01 from the .cue file... also remove the FLAGS lines...
then you should end up with a .cue file like nero may understand it... but then, I would not recommend burning bin/cue's directly w/ nero... it may be even better to use the daemontools in combination w/ direct cd copying.. -
Nero isn't a good proggie for burning CUE/BIN type images.
I strongly suggest CDR-Win, Fireburner or CDRDAO.
Regards.
Michael Tam
w: Morsels of Evidence -
HVR and Vitualis
Gentlemen,
Thanks for the info, I will try your suggestions and post results. I was begining to think it was all pilot error.
k5oz
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
