  1. I am using SpruceUP to make a DVD. It is of a show (Friends) and I have 5 different episodes (different file for each episode) and they will all play seperately throught the menu but I want to be able to put a button on there with a caption "Play All" and have it just go through and play them all 1 after another. I dont know if this is possible but I havent used it that much. Someone please help me.
    Dec 2002
    you would probolly get more help in a dvd forum
  3. In SpruceUp you would have to join all episodes together and make 1 mpeg file, and put it in the first play place holder and then create your menu and put the 5 buttons to each episode.
    But you probably want have the space on the dvd for that
    With Sonic DVDit PE you can do what you seek. with no problem
    Michael
    Learn to create DVDs the Ezway
    DVD Related Question Post them at
    www.EzDVDAdvisor.com
    DVD Developers Community
