My E-mail I sent a few WEEKS ago! (If you wanne skip the e-mail, more things below!)
I have 2 tv cards, a tv-live and a tv-radio live. Now, I have
got no idea on how to install them BOTH on 1 computer.
The tv-live one, it doesn't support any third party programs (only for 1
time after a reboot) except iuvcr, but this program is another thing.
The tv-radio live, it used to work on everything, but I can't get it
installed!
When I install a driver for it, the pc crashes. Although I DO use the
Win2K drivers!
Please help me as soon as possible!
Thanks!
Skerit
So, I ask for some help, Why the card isn't working iwth 3RD party progs, and they send me this. THEY SEND ME THIS!
Dear Sir/Madam:
The TV Card just can use on a system
Best Regards.
LifeView Support Dept.
Thank you lifeview, now I now the card can be used just because they say it! Yay! CAN YOU BELIEVE THIS???? AArrgghhhhh.... Anyway...
So, I captured something (I used my old card) but (ofcourse) it's interlaced. I tried the things at 100FPS.com, but they didn't work. quality is bad, but the original is good. Give me some ways to deinterlace it properly please.
Yo
I got me a lifeview to, the damn thing can't even give interlaced images cuzz of it's low resolution capturing abilities....(could it be a driver issue..?..)
The bugger was indeed hard to install under XP (dunno bout W2K), but i managed to get it working, so maybe try anutha PCI slot to get the damn thing(s) going.
What do u use for capturing ?
For V-Dub look up the de-interlace filters, just type it in on Google, ya get plenty of sites where u can download them....free of charge offcourse..
(i must admit it was a damn funny reply u got form Lifeview, i just ROFL'd a bit)
Scar -
Well, see this:
I bought a tv live card a few years ago, it was a good one, but I lost a small thing so I bought a new card, thesame, but without me knowing it, it used another chip, and used those lifeview software drivers and shit! Now, with the lifeview thing, I was able to capture at ANY size, but there was a problem, no 3rd party thing and in iulab no good audio. Then I just used my old card with the old drivers, an that was good, but now I just have the interlace prob...
I know those filters, i wanne know how to use them. I always get bad quality thanks ot it... -
Hi
Well just load your AVI, goto Video -> Filters -> add -> look for "deinterlace" -> load it -> and select your setting by trial and error.
I capped a minute test movie at 720x576 and deinterlaced it with the default setting (best) and it gives a good result.
U also might wanna try lowering ur resolution, works for me.
Goodluck.............Scar
Question about interlace problem
By jimdagys in forum Video ConversionReplies: 13Last Post: 19th Dec 2011, 11:40 -
PS3 Interlace Problem
By Anakin in forum Blu-ray RippingReplies: 5Last Post: 7th Sep 2008, 17:39 -
interlace - progressive problem
By jin007 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 10:55 -
(De)interlace problem on PAL TV
By Srivas in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 13:17 -
Interlace vs progressive DVD problem...
By main.dvd in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 08:53
