  1. does anyone know how to multiplex a divx file with
    ac-3 sound?
    im trying to make a divx with ac-3 sound and i dont know
    how to put the video + audio together.
    thanks
    HELL AINT A BAD PLACE TO BE
  2. Anonymous
    Guest
    use nandub,
    open the video
    select video->direct stream copy
    select audio->ac3 audio and open your ac3
    select audio->direct stream copy
    select file->save avi and it will multiplex the video and the ac3 to a new avi file(should only take some seconds).
    www.vcdhelp.com/tools#edit
  3. thanks, ill try that
    May 2002
    Rainy City, England
    You may need to play around with the audio interleave to avoid choppy playback. Typically try values between 64ms and 96ms.
  5. 64 is a lil tight.
    Try:
    128ms (both preload and interleave) for 448kbps AC3, 160 for AC3 384kbps, and 80ms for AC3 192kbps.
    Those generally work well
