I am convinced that life is one big learning curve of which I am always behind.
I just downloaded the full version of the Fx Mpeg Writer. After converting a MPEG file to a MPEG file with video extensions, I attempted to burn a CD with another application (Roxio Easy Creator 5). I received the following message
“This file will not work in a VCD player. To make this file video cd compliant you will need to use an MPEG encoder that supports Video cd encoding.”
What does this mean? Also, why does the program not recognize mov files?
i have encountered the same problem...a workaround that i'm doing is after converting, i open the converted file in VideoImpression (also a roxio application) and then save the file as MPEG-VCD (NTSC-352x240). hope this helps...
Thanks hed. That worked. I have no idea what I am doing, but your suggestion solved the problem.
The reason Roxio cd creator would not work is because it does not code video, you would need Roxio's video wave to do that
Help with making menu's!!!!
By BananaKing in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 08:55 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
