Hi,
I need to buy a good DVD player under 200 SD or 250 EUR (in Europe price are higher than US) with these features:
- full compatibility CD CD-R CD-RW (branded and bulk)
- full compatibility DVD-R DVD-RW DVD+R (branded and bulk)
- full compatibility VCD and SVCD (titles, subtitles, etc.)
- good MP3 management (directories and long filenames....)
OSD and full remote control commands.....
I like Sony DVP-NS405 (or 410 ...anyone know the difference???) or Pioneer dv-454 ...but has some problem with DVD-R compatibility... wht you suggest me??
If you want a player for a great price and one that will play anything you stick in it, get a Apex-1100W.....if you can still find a 1100W....if not, the newest model is 1110w and will also play anything.....NOT A Apex-1010, the 1010w will not play vcd but the 1110w will play it all even a mpeg file burnt as a data cd .... hope this helps
Buying a new BD/DVD player - What should I buy?
By BobLoblaw in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2011, 22:10 -
Buying a new BD/Divx DVD player - What should I buy?
By BobLoblaw in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Oct 2011, 01:13 -
advice to buy for dvd player
By rcrally in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2009, 16:24 -
Best Buy dvd player
By golfer in forum DVD & Blu-ray PlayersReplies: 7Last Post: 21st Feb 2009, 14:59 -
Buying a Divx DVD player.....Which one to buy.
By Hank Kinsley in forum DVD & Blu-ray PlayersReplies: 9Last Post: 15th Jun 2007, 10:53
