Hello I have a Canopus advc100 and can you tell me how you get it to work with win98. Thank you for your help in advance.
hi there
i have windows 98 second edition which i recommend and i can use the canopus advc100 analog \ digital converter.
first have ya got a 1394 firewire card for digital video\audio if, not get one
then use the firewire link from the
advc converter to your computer. then plug in the rc plugs from vcr or what ever source you have into the converter.
i have one and it is excellent quality very sharp in dvd format and even vcd format.
more or less you have to re-record your footage of video/audio onto your computer i hope you have a big harddrive cause one hr of uncompressed digital video\audio is
about 13 gb.
But of course you have to convert that to mpeg 2 or mpeg 1 compression so it can be played back on a standalone dvd player.
but you have to have a capturing software which does came with the fireware card or there are other software for recording like powervcr II and the software i use Sonic Foundry Vegas Video 3.0c which ya can get demo at www.SonicFoundry.com
and that about sums it up to use the device.
any questions just email me or write a reply and i might be able to help you even more.
Which Canopus DV capture box is best?
By Knightmessenger in forum Capturing and VCRReplies: 6Last Post: 26th Dec 2010, 18:59 -
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 04:26 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 17:09 -
Any Capture Card Still Run Under Win98?
By Ensign in forum Capturing and VCRReplies: 9Last Post: 17th Sep 2007, 13:16 -
DV Canopus Capture to XviD with MeGUI?
By Robert Simandl in forum Video ConversionReplies: 0Last Post: 21st May 2007, 17:43
