i used maestro for the first time last night and followed a guide step by step.
my problem is when the guide says its time to burn i thought i would look at it through powerdvd first to check it out but it loads up as if its ready to play it then just stays on the powerdvd screen.
any ides welcome.
thingimijig.
yep. get nothing.
i do the usual by selecting the video_ts_ifo to play the film but on this one i get nothing. -
if you havent set up a menu screen make sure you assign first play to the movie and it should play straight away
thanks for that, ill give it a go now.
another question is, is it posible to have one set of subs run as soon as you start the film (permanent subs)
thingimijig. -
if yo u right click on the disc icon at top of tree view then choose properties it gives you options on front page to assign sub titles try it you'll see what i mean
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Slightly OT: Input from Miro Users Needed
By terryj in forum MacReplies: 0Last Post: 29th Mar 2010, 08:31 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
