like Everyone else Here I am a bit new to all this .. But if anyone could help me I would apprecaite it ....... I want to be able to create a DVDR With the 3 vcd discs I have of LOTR put together
This is what I have done so far .... I have downloaded 3 Vcd discs Lord of the rings 1 2 3 they where in rar format so when i Unrared they became 3 bin Images .....
I then used isobuster to extract the Avi file from the Mpeg folder .... this produced 3 files which normaly have the avi extension... HOWEVER this time they didnt .... But I can open them using windows MP and they play fine ..... and I when I burn them on to disc and put them in my Standalone DVD player they play fine no problems ..
I then opened Tmpeg and tried to add the files together (As i want to be able to burn them to a DVDR Disc) .. fine or so i thought...... Howver when Tempeg came to File 2 it said it was Unrecognised format ! .... What do i do now I have read the Tmpeg fault sticky .. but it mentions a subject I dont understand ....
My questions are
1. am i using the correct procedure regarding extracting the image from the bin .... using the mpeg folder
if this is correct could you tell me what exactly i need to do next in order to stop Tmpeg rejecting the files please ....
I dont want to ask to many questions and i know that i have to rencode the sound but If I can at least get past this stage then id be happy
thanks for looking in
