I'm trying to burn my vcd mpg's created with tmpgenc, but it gives me a message the file is not vcd compliant and will be re-encoded b/4 burning. Is there any way to turn off this message and burn file as is???? If not, can anyone reccomend software that doesn't do this. Thanks ALL!!!
Nero should also give you the option to continue without encoding. You are obviously doing something wrong with TMPGenc though so read through some of the guides on this site - nero should burn a VCD compliant MPEG straight off.
when you create a new session there should be a little box that says something about create compliant vcd. just uncheck that and click new.
nero 11 express
By tarzan54 in forum Authoring (Blu-ray)Replies: 12Last Post: 10th Feb 2012, 00:28 -
Nero Express stopped working - why?
By TexAsh in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 15:28 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Nero Express stalls out
By tommyboy9495 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2007, 15:03
