Is it possible to convert a divx moive into a vcd format with nero burning rom? But how u do it? and also i need to know if the divx file is PAL or NTSC so nero can find out which one it is. Please help thank you.![]()
Goku Rocks
Montell,
Some of the best and simplest to understand step-by-step guides are shown on the left of the screen under "HOW TO" (the green area).
I would suggest starting with "NEWBIE" and when you get to that page scroll down a little to the section titled "Newbie beginners guides"
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 11:37
