HI,I'M PLANNING TO BUY A DVD BURNER,BUT I WANT TO BUY ONE WHICH'S CAN BURN OLSO "DTS" SOUND,WHICH ONE DO YOU RECOMEND?![]()
I think they all suit.
DTS is just another audio stream in the vob file - if it is present in the original movie.
So you determine what to rip/burn from/to a dvd disc.
I suggest you read carefully the rip guides and experience a bit with them. If you do not, you will never understand about these 'streams' and 'vob' stuff.
But some more expirienced user should comfirm/reject this as i am also a newbee with this stuff. -
All the burners out there do DTS, all you have to worry about is what type of burner to get.
DVD-R(W) e.g. Pioneer
DVD+R(W) e.g. Philips
DVD-R(W) and DVD+R(W) e.g. Sony
The media for DVD-R is currently cheaper but isn't expected to last, and DVD+R is better for video authoring.
I recommend the Sony drive because it can do both formats and has a nice 8MB buffer (Less Coasters)
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
DTS to AC3 "static" on recent MKV's
By satviewer2000 in forum AudioReplies: 2Last Post: 24th Oct 2009, 01:23 -
Compatible Burner for Womble's "MPEG Video Wizard DVD"?
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 22:25 -
VRD-MC3 "Copy Protection Signal Detected: Cannot Record"
By cmwalsh in forum Capturing and VCRReplies: 6Last Post: 14th Jul 2007, 11:03 -
No sound..."feature missing: DTS Decoding" ?
By vm711 in forum DVD RippingReplies: 2Last Post: 15th May 2007, 16:59
