Here goes...super-newb....I've tried and successfully copied the easy method using Decrypter on DVD-5...now I'm moving on and hitting walls...I tried the install of over 4.7 and used Nero (here comes the newb part) and the info on the left, where the tabs are, has vcd, cdr, svcd....but no DVDr option...I have the new Nero, but obviously missing something. I want to be able to burn OVER 4.7 on 1 disc NOT 2...can I just buy DVDxCOPY and do this OR does that also burn to 2 discs...Also, are the IMATION DVD-Rs good to use...I'm looking for a guide or step by step process that's tried and true. ANY help will be much appreciated!!!
If this country is to take a swing in the right direction, we need to start holding ourselves accountable.
you two options when the dvd is over 4.7 gigs. that is to encode the video to a samller size or split it onto 2 dvds. which is what dvdxcopy dose. the best thing to do is read the guides here on coping dvd9s to dvd-r....
I just used this program DVDXCOPY v1.2 it will do what you need.
It is very idiot proof. I think you have to pay for it, but I know there are places to download it on the internet. -
If you want only the menu with no extras or menus on the disc look here.
http://www.vcdhelp.com/forum/viewtopic.php?t=121195 -
Will it not lose the QUALITY going from dvd2vcd....I want to keep quality, want on 1 DVDR, help on the NERO issue, and should I use the IMATION dvdr's...Thank you for all your responses and patience, still learning here!!!
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
