features added:
Added frequently-requested Lanzcos3 kernel to resize filter. Can't see any difference whatsoever.
bug fixes:
Fixed nasty resize filter bug and RGB24<->RGB32 conversion errors on odd bitmap widths. (Regressions in 1.4.12)
Fixed audio desynchronization when processing compressed audio in direct stream copy mode with both a start offset and deleted segments. Thanks to Cyrius for the bug report and fix.
Audio compression system now drops a final partial block from an audio codec -- Microsoft ADPCM was producing these, resulting in a runt AVI stream sample. The new behavior matches that of Sound Recorder.
A partial final block no longer triggers the VBR audio adjustment routine.
"Previous keyframe" from beyond the end no longer seeks to start if frames have been deleted or masked. Also thanks to Cyrius.
Fixed crash in MPEG-1 decoder when playing or saving a video stream with D-frames or invalid frame types.
B-frame audio skew support is now also enabled for the 'XVID' video format.
Download http://www.virtualdub.org/download
Sorry but old news. It's been out about a month now.
Warning! I'm baaaaaaaaack
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
New Free Virtual Studio Backgrounds released
By Shubi in forum Latest Video NewsReplies: 1Last Post: 22nd Jun 2008, 18:01 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00
