I have a AVI film that when I put it into Virtual dub (latest version) it throws open a small window stating that **Parsing interleaved MPEG file** also G spot ID's it as an Mpeg so how can I go about saving it from virtual dub as a legitimate AVi file that I can encode to Mpeg2 for DVD Authoring??
Thanks in advance
Well it seems obvious to me that it is not an avi file but is in fact an mpeg file, so change the file extension to .mpg.
It must be mpeg-1 as vdub does not open mpeg-2 so that helps us a little. I suggest you get bitrate viewer (the freeware version) and check out its properties. If its resolution is VCD standard then there is no pint re-encoding as this is valid for DVD. Just demultiplex the audio (using TmpGenc mpeg tools) and change to a 48khz sample rate, then author.
There is a guide under authoring on how to put VCD video onto DVD-r. -
Hello again
I put it in to TMPGenc and encoded it to Mpeg2 from mpeg1, dont know if it was supposed to work like that but it did and I authored it with no problems to DVD-R
I do need your help with with another topic I posted in the forum about havin no sound in Mpeg2's. I understand about searchin the forums for answers before posting questions but im I have done that and im stuck
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 16:08 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 21:27 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 23:47 -
Settings in ffmpegX for odd size .avi files
By sknox in forum ffmpegX general discussionReplies: 2Last Post: 8th Jul 2007, 23:32 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 02:58
