  1. Gday all ..i was given a dvd player as a gift ...it is only badged as an "cce"
    Although it says that it is cdr , cdrw compatible it will not play svcd's '
    any help would be much appreciated, id like to try and get it to work before i give it back...lol
    it was about £65'ish from superdrug
  2. go to the left of the screen and look up your dvd player under dvd players compatiblity. it might only play vcds. or you scvd is non stantard and thats why it is not playing.......
  3. thanks for that quick reply.... i should have stated that a friend also has 1 and he has heard of a way of getting it to work on another forum ...but i cant find it.doh ..gonna be up all night looking
  4. http://www.dvd.reviewer.co.uk/forums/thread.asp?Forum=176&Thread=128573
    sorry if i got the thing above wrong..plz delete..but i found the info ...thanks again
