When using the source range in TMPGEnc to cut movies I often get the bar to slide at first and then it locks up. If I let it sit for a few minutes it usually unlocks but not always. If I try to exit out of the program it says that (this program is not responding). I have even un and reinstalled the program. Am I doing anything wrong? I am using the guides from this site to create my svcds.
Do you have all the right codecs?
Close all other running apps and programs running in the background"Today is only yesterdays tomorrow"
Understanding TMPGEnc source material settings
By brassplyer in forum Video ConversionReplies: 1Last Post: 5th Mar 2011, 07:41 -
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 17:52 -
virtualdub problem: source image format is not acceptable
By jorwex in forum Video ConversionReplies: 12Last Post: 2nd Sep 2009, 06:01 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48
