Ive got a svcd in bin format and when i should burn it in nero how do i add subtitles??
I wish you could answer as quickly as you can!! :![]()
You must extract the video from the bin and then add the subtitles to the mpg. Use cdmage,isobuster or virtual daemon www.vcdhelp.com/tools#other
Then you can either add svcd selectable subtitles with maestrosbt and winsubmux http://www.vcdhelp.com/tools but they dont work on all dvd players. Or you can add none selectable subtitles that requires that you reconvert the svcd, you can use dvd2avi -> vfapi -> virtualdub with subtitle plugin and frameserve to tmpgenc. www.vcdhelp.com/mpeg2tovcd http://www.doom9.org/mpg/vfapi_reader_codec.htm and http://www.vcdhelp.com/forum/userguides/87065.php
subtitle problem
By cloudsong in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2011, 16:18 -
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 09:44 -
Subtitle Problem
By simonrule in forum SubtitleReplies: 1Last Post: 10th Oct 2009, 17:59 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
a problem with subtitle
By matrix man in forum SubtitleReplies: 1Last Post: 15th May 2007, 13:36
