When I try to write a VCD using NERO. the CD has five directories
VCD, SEGMENT, MPEGAV, EXT and CDI.
Any idea what I am doing wrong - I tried to input .mpg and also .avi - it accepted both but wrote only these di rectories on CD.
Help !!!!!!!!!
I really think you should read thru the how-to guides. In any case those directories are supposed to be there. Inside the MPEGAV folder you'll find the AVSEQ.dat file which is where the MPEG file is written to.Originally Posted by bulsiWarning! I'm baaaaaaaaack
Thanks for the info. But I cant find a how - to - guide explaning these direcotries on Nero.com or anywhere else.
The VCD says written succesfully but doesnt play.
Please help this ignorant newbie. -
bulsi,
If you follow the link I provided about half way down the page is an explanation of the file structures on a VCD: http://www.vcdhelp.com/vcd.htm
As to the playback problems check in the DVD Players compatabilty & user comments section of the forum listed on the left hand side of the page to see if your player is listed.Warning! I'm baaaaaaaaack
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 06:41 -
Need help using Nero 7 writing
By tcory in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2011, 16:19 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
Renaming Directories - XP Crashed - NTFS Drives
By wormhole1969 in forum ComputerReplies: 8Last Post: 18th Nov 2008, 18:15 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 06:15
