Just wondering if I am the only one who cannot get DVDBackup 1.3 to function properly under 10.2.2 and 10.2.3. It will always return an error while ripping the final .VOB in the chain. Very strange. Yet DVDBackup 1.3 works just fine under 10.2.1 - but anything later is no go. I've tested and retested using various discs, even reinstalled 10.2.3 but still the same problem. I've kept 10.2.1 on a separate partition just to use DVDBackup, but it does seem silly to keep this partition solely for this purpose.
So is it just me or has anyone else experienced this problem? And, if so, any idea what is causing it? Thanks.
I am newbie to the forums but have been experimenting with vcd's and dvd's for a few months now. But I also have the same problem with DVDBackup. I am glad I saw your post. Thought it was actually a problem with the DVD I was using. But seeing your post made me remember that I did the 10.2.3 thing also. Went back to using DVDExtractor in Classic.
If the Thunder don't get you, the Lightning will!
