Okay i use virtual dub to extract the audio.I use TMPG to convert.I have read every help guide on here and my audio synce is still out.Any suggestions.
Audio will be fine but will go out than come back in than go out and come back into Sync.
Should i try another program?If so what besides TMPG would you suggest.
What format is your video file?
What format are your converting it to?
and What software are you using to play it?
Answer those and I will be able to help you more briefly!
Thnxs -
My file is Divx i'm trying to convert it to Mpeg for vcd and i use my home DVD player.It seems that TMPG works for some and then other they are all screwed up.
can u just load up your divx movie into TMPGEnc. then just encode it to vcd.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
