Hope someone can help. I have been downloading avi files for ages now and have only recently noticed that all my converted avi and xvid movies have perfect audio but a slight slow down in motion.
I use the same frame rate etc as the source file but every 5 - 10 seconds or so the movement will slow down.
I am using TMPG to convert the files and have tried everthing i know. Has anybody else been having similar problems?
Please Help!
Mat
Results 1 to 10 of 10
what are you converting it to? what format?
and what software are you using to play it? -
Doesn't matter what i convert it to and what bitrate it is. MPEG 2 & MPEG 1 both have the same slight jerkyness.
I have used WMP, Playa, Vidomi, WINDVD and my Pioneer 444s dvd player for the resulting burned svcd/vcd.
Mat -
Im getting the same / similar, posted today, no replies
http://www.vcdhelp.com/forum/viewtopic.php?t=132180
surely others must have this ,and surely someone must know what the answer is ? if not mthorburn , keep with it , make a note of exact settins , movies etc.. ill do the same and see if we can come up with omething ourselfs
stay with it dude, keep me updated
Hmm seems strange, well my possible answer to this would be the codec the divx/xvid carries within the avi file.. And tmpgenc is ignoring that fact that it jerks.... umm try to convert it to normal AVI and then re encode it to mpg
best reagrds -
I'm also having that problem. I have converted a few xvid movies to svcd and have noticed that when play them back on my dvd player that the do stutter a bit. Using TMPGEnc to convert and splitting the movie over 2 cds. Anyone shed any light on this??
Fighting online is like the special Olympics, even if you win, your still retarded :/ -
I too have the same problem!!!!!!!!!!!!!!!!!!!!!
I dont know if its just me but ever since the xvid codec started to be used it made the issue of codecs more problematic. I had to try three different codecs before I could get one that actually worked on my pc.
I like DivX codecs more!
I had a post on the same topic:
http://www.vcdhelp.com/forum/viewtopic.php?t=131058&highlight= -
I agree, It's not a problem with TMPG cuz it works fine when u rip a dvd and encode it with TMPG.
It's the codecs and the lack of compatability with programs. -
in tmpgenc
try using 'AUTOMIC VBR (CQ_VBR)' under rate control mode.
and MAKE SURE you choose a motion search besides 'motion estimate search (fast)'
I had this problem and posted it here. Those settings solved my problem with video pausing or jumping or skipping with newer AVIs I converted to mpeg2 in tmpgenc. My player was an apex 1010w. Let me know if this helps."True POWER goes to the ones who know POWER Starscream, Desire alone is not enough." -Megatron
-=Sabrtooth
MKV newbie - video slightly skips using MPC
By captenblack in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2009, 19:41 -
Slightly Choppy Youtube Video
By jooleyen in forum Video Streaming DownloadingReplies: 4Last Post: 9th May 2008, 00:54 -
Resizing interlaced video - slightly confused at the process
By PTRACER in forum EditingReplies: 2Last Post: 7th May 2008, 07:14 -
Building A Video-Editing PC (slightly off topic)
By GrayStrickland in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th Feb 2008, 13:39 -
video is slightly wider than the tv screen.
By aruwin in forum EditingReplies: 8Last Post: 21st Jun 2007, 11:57
