  1. I am using Scenealyzer for capturing DV from a Camcorder through I.link.
    My problem is that this capturing software creates many files of the DV being captured. Is it possible for this software to just create one file rather than many.
    I tried seeing if there is some kind of setting or paramters that need to set/changed but couldn't find none.
    Any help is highly appreciated
  2. File>Options>Capture[Tab]>Under Scene Detection, select no scene detection
    If you have an NTFS drive and don't want the 2 or 4 GB file break, select unlimited (for NTFS only) under max .avi file size.
    HTH
  3. Thanks firetoad it was helpful
