Is it possable to completly remove the audio from a mpg or avi file without reencoding? And if you have to re encode can virtualDub or tmpgenc do it....if so....is it easy to do.
thanks
casba44@hotmail.com
in case your wondering.....hehe
i want to merge a bunch of mpg files and strip the sound
virtualDub,open the avi
audio > no audio
video > direct stream copy
then save as avi
for mpeg:tmpgenc,haven't done it,but there is a setting in the audio to turn down the volume -
Thanks zodiac for the info....much appreciated. I use more mpg files so any info on how to do this would be appreciated....messed around with tmpgenc but couldn't figure out.....the avi files with virtualdub works great thanks again zodiac.
TMPEG can separate (de-multiplex) the audio and video on mpg files. Start TMPEG and bypass the project wizard. Go to File... MPEG tools. Choose De-multiplex. Load in your mpg file. Hit run and you shoud get two files. One audio and one video.
Good luck.
How do I strip an MPG 2 of language streams W/O reencoding
By Onceler2 in forum Video ConversionReplies: 17Last Post: 22nd Oct 2011, 07:16 -
Strip audio track from AVI
By exekutive in forum MacReplies: 12Last Post: 2nd Feb 2011, 17:25 -
remove audio part of mpg
By zmartha in forum AudioReplies: 5Last Post: 19th Oct 2009, 19:51 -
How to Strip Audio from an AVI?
By MadisonMax in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 13:53 -
Remove audio from .mpg clip?
By Silvy in forum AudioReplies: 4Last Post: 24th Jun 2007, 18:41
