Is there anyway of setting a VCD as 16:9 DAR? What I'm trying to do is let the player automatically switch the aspect ratio on the fly, but it's not working.
The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002
MPEG Sequence Maker can do it!
You need to demux your MPEG to the elementrary video and audio streams first.
Load the elementary video with MPEG Sequence Maker. Go and change the options --> aspect ratio.
Save your new elementary video file.
Remux your new video and old audio together.
http://www.vcdhelp.com/tools
Remember, not all (probably few) players respect the 16:9 DAR flag for VCDs... But give it a go.
Regards.Michael Tam
w: Morsels of Evidence -
Thanks! I'll give it a go and let you know if I have a problem!
The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002 -
OK, so I've demuxed my file, I've changed the aspect ratio in MPEG Sequence Maker (I've chosen 16:9, NTSC) since my sample is 16:9, and I've multiplexed it.
The aspect ratio remained the same.
I'm using PowerDVD to view the clip. I have yet to try it on my player. I'm thinking that maybe I missed something, but I don't think so.The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002 -
If you load the newly saved elementary video file back into MPEG Sequence Maker, what does it say that the aspect ratio is?
Perhaps you can't use it for this after all...
Regards.Michael Tam
Virtualdub: DAR?
By higgins327 in forum Video ConversionReplies: 4Last Post: 1st Apr 2011, 06:42 -
Dar, sar...
By drgt in forum Newbie / General discussionsReplies: 44Last Post: 13th Dec 2010, 13:09 -
lost with par, dar etc
By kkiller23 in forum DVD RippingReplies: 12Last Post: 16th Sep 2010, 23:05 -
Video DAR vs PAR
By tb582 in forum Newbie / General discussionsReplies: 7Last Post: 28th Apr 2009, 13:04 -
Change DAR of MPEG-1?
By vonzippa in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 20:17
