Since this is 1 of 2 drives that currenty support writing DVD-Audio, I thought it might be a selling point if it actually works well. Anyone know?
DVD Audio should work with all DVD writers but you need some kind of authoring software for DVD Audio like http://www.discwelder.com/ (which is expensive). So no, that's no selling point for the HP burner.
Yep, -jsl- is right. DVD-Audio is just another DVD-Format. Maybe you've explored a Video-DVD and seen the AUDIO_TS folder. Can you imagine for what this is?!
And, ESPECIALLY no selling point for the HP burner! HP had the most trouble with the law and the industry fighting about CD-Burner charges...
I only was confused because the DVD burners in the DVDWriters section here all have DVDAudio writing greyed out, meaning it wasn't tested. The only drive with it actually highlighted as known to be supported was the HP. So all drives can do DVDAudio?
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 19:23 -
Burning DVD audio problem
By Jragon16 in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2009, 23:20 -
Burning mp3 audio files onto a DVD
By DKRoff in forum AudioReplies: 4Last Post: 23rd Oct 2007, 06:05 -
Audio syncing when burning DVD's
By thatoneguy99 in forum Authoring (DVD)Replies: 2Last Post: 21st Jun 2007, 03:43
