I have joined 3 svcd files together, the problem is that the total size of the joined file is 2.3 gb. When i try to view the file with power player I can only move the slide control to about 1hr 3min. I have tried other 3 disk svcds and same problem. When I then try to convert the file to dvd-r it only does 1hr 3min . The file system I use is ntfs. Any ideas as I know it is something to do with the size of the file.
thanks
Derek
How did you join the files? If you just merged it with a DOS copy, processing stops at the end of the first part.
How long is the entire video? Maybe the first 1h 3min make up 1 GB and your software has a 1 GB file size limit? I think that's why you get several 1 GB VOB files when you rip a DVD.There are only 10 types of people in the world:
Those who understand binary
and those who don't.
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
Joining MKVs
By Amanaman in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2009, 12:27 -
Improper joining?
By LWC in forum EditingReplies: 6Last Post: 21st Mar 2009, 20:58 -
Joining
By breeze9 in forum EditingReplies: 2Last Post: 30th Dec 2007, 16:14
