Ok i have TMPEG thats cool just add some basic chapters nothing to fruity.
i also have uleadworkshop "trial version.
And no matter what i do i cant get it to detect or import a file wierd noi?
Also i am ready to burn[thats write mr club has ripped a perfect DVD]
I have "nero" Is that what i should use?
also i have 700mb cds how much mpeg2 can a 700mb cd hold then i can get an idea about how large a chapter should be?
so hope to hear from you soon im itching to "burn".![]()
so the guy punched me, and later i stole his parrot as way of revenge
I have never had luck with Nero or ULEAD. Personally I think VCD Easy is the way to go - it has an easy interface and there are good tutorials available. At fist glance they seem complicated, but just copy them and read thru it step by step. With VCD easy you will make a cue/bin file on your hard drive. You can then use Daemon tools to mount(play) the file to insure everything is like you want it. If not you can make adjustments, redue the cue/bin before you burn the cue/bin file to a disc.Since you have an MPEG 2 you will be making a SVCD. At the standard bitrate you can get about 30 min on an 800 mg disc. If you want you can adjust the bitrate in TEMPG to a lower value and get more on the disc. You can find all the programs in the tools section
Good Luck!
http://www.vcdhelp.com/sefy/?id=chapters2.html
http://www.vcdhelp.com/forum/userguides/104503.php -
i have vcd software
thats what my face looked like when i read about it
chapterX stracter i pasted the chapters to vcd and it worked.
im still learning though i have to get some MORE
software to put in that beast.
i belive i should stay with VCD as like you said i found out it only holds about 30_35 mins that was like 3 disks for the hole film lol.
But once you have done it you can do it again and get fasteer and better.so the guy punched me, and later i stole his parrot as way of revenge
Best method for splitting up an .avi into various chapters and burning
By aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 20:24 -
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 01:11 -
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 02:11 -
Burning chapters on I-DVD
By Tom in HD in forum MacReplies: 1Last Post: 19th Jan 2009, 06:18 -
VOB editing before burning (splitting, chapters, etc)
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 08:29
![Computer details: win xp
thalon 1800xp[true1500]
80gb IBM. 9Gbmaxtor:]
256sdram
hercules 64meg
whut?
soon
N/A
pioneer ??
N/A soon
N/A
KT3 ultra2
inbuilt soundcard on motherboard Comp](/images/buttons/computer.gif)
