ever time i use chapter x-tractor v.0.962 and try to load the chapter list in dvd maestro. I get this error "I-frame insertion entry frame rate is not consistent with current tape frame rate!
Movie is 29.97 fbs drop
Chapter x-tractor is set to 29970
i used dvdmaestro setting in chapter x-tractor
please help..
Chris
if u use dvd decrypter , you can make it extract a chapter list file 8) which then you can import into maestro.. works 100% for me :P
Change to DVD Decrypter . Bigsyd is right - it will do it all a treat. I always used smartripper , but not now.
Wha program do you transcode with? and what process cause some encoders do this very badly when loaded into Maestro.
There are even the way I do it a few that misbehave, but I just manually enter the chapers then and get them "close enough" and call it a day usually. -
I am getting the same error! You must be using DVD2DVD-R and have "SCEANEST NT" selected on the first menu and in the SETTINGS tab have "author" or something like this checked (at work and don't have the program in front of me).Originally Posted by skyhigh20
Maestro allows you to manully enter in the chapter points. You can look at what was created by chapter x-tractor or there is a .txt file in the directory that DVD2DVD-R created that contain the times for the chapters.
To enter the times manually just click on the "chapter bar" in the "movie" area and manually enter in the 10 or 20 chapter points. -
Thanks for the reply's all.
I am using DVD Decrypter now, and everything is working great....
Chapter list Menu problem with MultiAVCHD
By Jijital in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Feb 2012, 16:29 -
AVStoDVD Chapter Problem
By adyf in forum Authoring (DVD)Replies: 11Last Post: 21st Dec 2010, 14:03 -
Can't control custom chapter list of tsmuxer.
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 26th Mar 2010, 03:08 -
DVD to DivX - Chapter Decoding Problem
By Nuin in forum DVD RippingReplies: 0Last Post: 25th Mar 2009, 17:56 -
Import .chp list from ChapterXtractor to Maestro error
By rbatty11 in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2007, 12:20
