Can you tell me how to create VCD using TMPGEnc, when i use the s/w it converts AVI to MPEG file. But When i create VCD using Studio 8 it creates couple of directories (EXT, EPEGAV, SEGMENT, VCD) and files (*.VCD) which i can play directly into DVD player. But TMPGEnc is not creation these files. Do I need to use different s/w to convert MPEG into VCD files ?
Ramesh
Creating the VCD directory structure and all the necessary files is the task of your authoring program, p.e. Nero.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
Thanks for the reply.
Can we use Pinnale to load MPEG and create VCD or nero is better option ? or other s/w ? -
Nero is easiest to use. And it doesn't create large temporary files like WinOnCD does.
Nero might be easiest, but is still not a VCD authoring application. VCDEasy is much more versatile (for authoring), and not that much harder to understand. If your CD writer is supported, it can also write the VCD image to disc. If not, just take the output from VCDEasy to Nero, and let Nero do what it's good at: Burn CD's!
/Mats -
Originally Posted by w3help
TMPGEnc DivX conversion BLOCKED-LIKE avi
By visitor in forum Video ConversionReplies: 2Last Post: 26th Dec 2009, 10:32 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46
