I have made mpeg2 files (svcd) but for some reason vcdeasy wont let me combine like 15 250mb files it gets integer errors.
So my player can play just mpg files on a disc so will i loose quality if i just put all 15 files on a dvd-r and not make it a svcd?
Also will the timing go out of sync or anything funny like that?
THanks
Theres only one way to find out for sure and I think you can probably work out what it is!
BTW, you can't actually burn (S)VCD to DVD-r, though you can author VCD or SVCD standard video to DVD-viode format, with a little work.
How can split a mts movie file without loose the quality
By siopilos in forum EditingReplies: 5Last Post: 15th Feb 2012, 15:57 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 09:40 -
How do I compress my analog-to-DVD's and not loose quality?
By Theresa in forum Newbie / General discussionsReplies: 13Last Post: 8th Jan 2009, 18:06 -
Putting two AVI files on the same DVD
By Mr Sorrow in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2007, 08:57 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57
