I am relatively new but have successfully burned several VCDs using TMPG and the standard templates. I usually eliminate chaptors so they fit on 1 80min disc. I decided to unlock the templates so I could play with the settings and reduce the bitrate to allow something longer than 80 mins to fit on 1 disc with decent quality. I used a CBR about 850and used MP3 128 to make more room for video quality. I created an MPEG that plays fine with good A/V sync , decent quality and good audio, but when I used VCD Easy to to burn the disc (Daemon test and CD-RW) the audio sounds stacato or chopped up. I never experienced this with the standard template. The video is still fine. I have used VCD before with good results.![]()
The reason why your audio is probably garbled up is that VCD doesn't support .mp3 audio. Your audio must MPEG-1 audio. I hope this guide will help you:
http://www.vcdhelp.com/virtualdubaudio.htm
Hope That Helps!!! :P -
MP3 audio is MPEG-1 Layer 3 audio.
S/VCDs only support MPEG-1 Layer 2 audio (or MP2).
Even though many modern DVD players support MP3-CD-ROM play back, they will NOT play VCDs with MP3 audio.
Regards.Michael Tam
w: Morsels of Evidence -
Thanks for the reply, but I guess assumed the 128 was MP3 and I was wrong. I looked at the TMPGE "other settings: Audio" and it indeed says MPEG-1 Audio layer II, 44100 Hz, Stereo, 128 bits. Could it have anything to do with wheather it is NTSC vs NTSC Film. I have the Force film setting checked, but again the resulting MPEG 1 plays fine in windows media player, it's after I have tried to create an VCD that the problem appears. I also selected MPEG 1 Video CD ( non-standard) under the system tab as the video bitrate is non-standered. This problem only appeared after I started tinkering with the standerd settings. Frustrated!
Avidemux - WMV file convert to MP4 - Audio stream garbled
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 14:52 -
Easy & free Way to Translate Subs
By sam999 in forum SubtitleReplies: 4Last Post: 21st Jul 2010, 11:08 -
Garbled audio playback in snow leopard
By several in forum MacReplies: 3Last Post: 5th Nov 2009, 09:06 -
Garbled Audio in Nero Dvd project - Video is fine - need assistance please
By RossChurchill in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2008, 15:44 -
Audio is garbled in WMP when viewing video clips
By mowermanEd in forum Newbie / General discussionsReplies: 2Last Post: 8th May 2007, 02:48
