I recently bought my first DVD-player (Mustek dvd560) and i works like a charm. Apart from a very thin users manual I'm satisfied. One problem though. You're supposed to be able to choose a default subtitle language in the menu system. But if you want swedish like i do you have to enter a code. I can't find the code anywhere. Can anyone help me please?
Results 1 to 1 of 1
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
Code Free for Mustek Yukai MP76A
By eagle1200 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 11:14 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
