Hi!
When I convert my DivX movies to scvd using TMPGEnc everything works fine untill Ive burned them and but the disc in my dvd. Then somethings fukks up, The size of the letterbox doubles and the picture gets squised.
I have no idea how to fix it so please help me. I followed the guide "How to convert to SVCD with TMPGEnc" in the convert section then I burned using Nero 5.5.9.9
/kul4n
Results 1 to 9 of 9
I recommend using an avs script producer like Fit CD, and open that in Tmpeg instead of just opening the avi directly.
If you dont know what i mean, get back to me and i'l explain in more detail.
Hi
Sorry, Im a complete newbie and just started out so it would be very kind if you could explain in detail.
Thanks for helping out!
/kul4n -
Make sure under the Advanced Tab, that you set the source aspect ratio to 1:1 (VGA) as DivX is always 1:1 (VGA) for the source aspect ratio. Also, under the Video Tab, set the aspect ratio to 4:3 or 16:9 depending on what type of T.V you have.
Hope That Helps!!!
:P
thanks. Ill try that out just now...hope it works!
Thanks again!
/kul4n -
you know, i also have this problem, but only for some movies. Some are ok, some are really squashed, but still watchable. I heard you can use FITCD to set the aspect ratio, but dunno how to do it tho.......any ideas.....
usually i just do trial and error with the aspect ratio 4:3/16:9 until i get one that is accetable
From 4:3 letterbox to 16:9
By Crueltylizer in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2010, 10:40 -
Another 4/3 letterbox to 16/9 WS question
By julitomg in forum EditingReplies: 7Last Post: 4th Dec 2009, 16:21 -
Letterbox 4:3 to Anamorphic 16:9
By sjdean in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 17:09 -
letterbox to 16:9
By marksk918 in forum Authoring (DVD)Replies: 9Last Post: 30th Aug 2008, 02:33 -
very very thin letterbox
By mark o in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 17:17
darn.
