I have been wanting to know if anyone has had any luck capturing directly on their PC from a DVD in the DVD Rom drive? I mean direct capturing of clips/segments off the DVD to say an .avi file or mpeg? Obviously you can rip the whole DVD, etc., but I want just want to capture small specific clips from some DVD's (not the entire thing). I know you can plug a DVD player into a capture card and try it this way (although copy protection usually interferes). There are a couple of pieces of software that will capture what's on the PC screen to video, but I think you lose the sound this way. If anyone has some suggestions about this, please reply. Thanks!
The way I capture just a small clip is to use SmartRipper, find the chapter that the clip is on, and rip that chapter. Then I use DVD2AVI 2 frameserve that chapter and extract the audio. Then I use TMPG to convert it to select the beginning and ending points and convert it to avi.
can I burn avi's direct to jump drive or computer desktop Toast9
By BattyRoy in forum MacReplies: 4Last Post: 10th Aug 2009, 00:06 -
Direct from DVR to computer hard drive?
By jdcrowley in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Sep 2008, 22:08 -
Hard drive camcorder direct to DVD burner?
By h08 in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Oct 2007, 18:47 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 16:28 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
