well, I have some divx episodes and I want to convert them to a vcd mpg
i use TMPGEnc to convert it, but I can only make it work by setting up a PAL vcd
my tv uses NTSC so I want to convert it to that, but when I tried it, the video didn't stretch to the whole tv. I figured it had to do with the sizing, but the audio was choppy too
could someone please help me
like with the right settings and screen size, frame rate and all of that stuff
mainly though I want the video to fit the tv, so please help me with the size factor
What do you mean that the screen size was wrong? Was the source 16:9 letterbox and you want to make a 4:3 'normal' screen movie? That only part of the video showed up and the rest was cut off? That the movie was 'squezzed' into the top right corner of the screen, etc. etc.
What do you mean you could only get TMPGenc to work by setting up a PAL VCD? What happens when you load the NTSC VCD template? Does TMPGenc give some error, does your computer lock up, etc. etc.
We need a little more info. I would suggest that you read the guide to the left under 'Convert' for converting a DivX -> MPEG and see if that helps too. -
YOu can try this China program, It called herosoft, vituallu converts any avi to mpeg1. Unfortunalty, its website is in chinese. 30 day trial though
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 21:12 -
mpg plays badly in divx dvd player
By ssalim in forum Video ConversionReplies: 25Last Post: 3rd Apr 2009, 10:39 -
DOS multiplexing for DivX and/or other MPG?
By Figge in forum Video ConversionReplies: 2Last Post: 25th Mar 2009, 02:55 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
mpg/divx --> 3gp anyone?
By trancer_84 in forum Video ConversionReplies: 7Last Post: 6th Nov 2007, 10:32
