I ripped the dvd with smart ripper.
Extracted audio files with dvd2avi.
Then ran Tmpgenc to re-encode.
Ran Maestro to author and create the video and audio directories.
Burned dvd with Prassi Primo.
The copy is excellent.
My only problem is that it won't autorun, Just shows a black screen. You have to press the play button for the film to start.
I presume I have missed out a setting in Maestro, could someone please tell me what it is.
Also how do I set the default film type in Maestro to PAL.
Thanks in advance.
Ok after your finished laying the dvd out in dvd maestro . delete the menu (if there is no menu) minimize you movie window and you should see a window with First play at the top. Drag your first chapter (00:00:00:00) to the first play line and drop. Now compile. Play and presto autoplay.
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 03:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
