Thanks to vcdhelp.com comparissoncharts I consider buying a Matrox Marvel G400 - TV card. It will be my first step in videocapturing.
I have a P II 350 with 128 MB on an Asus P2B board with 440BX chipset (all dated from 1998 ).
As I understand the G400 - TV should run just fine on my system (?).
There is one point that is troubling my mind: the 2 GB AVI capture limit for Windows.
Is there any solution covering this problem. As I was comparing with Pinnacle Studio DC10+, I discovered on their website a software update that fixes the 2 GB limit (: http://www.pinnaclesys.com/support/display.asp?FileID=577&ProductID=307).
I'm told about the marvelous rock solid support Matrox offers. So I hope there is a fix. Does anybody know?
After that nothing can stop me from buying it, true?
The 2 gig limit applies to any standard AVI.
Having said that, both VirtualDub and AVI_IO can do what are called multi segment captures. They simply finish one file and start another in a numerical sequence on the next frame so you don't get any frame drops this way.
Then you use VirtualDub to edit your capture. It sees the multi segment capture as a single file. You can then save it as an edited multi segment output or frameserv it direct to your encoder.
Either way, you don't need to worry about the 2 gig limit.
By the way, I've got a Matrox G400 TV. The statements above are exactly what I do.
Hope this answers your question.
Ian -
Ian,
Thanks for your advise. In the meantime I've bought the Marvel G400 TV. It's up and running
I also downloaded AVI_IO and that looks fine too.
Starting my capture career now I have another question about the best way to make SVCD of VCD out of analoge Hi8 tapes, but I will post it seperately.
Thanks again for your good help.
JW
Emulate MATROX-AVI
By elmuz in forum Video ConversionReplies: 12Last Post: 4th Jul 2013, 14:49 -
Matrox AVI, 50fps and Adobe...?
By dr_shabzzz in forum Video ConversionReplies: 1Last Post: 17th Sep 2011, 08:53 -
How to Import Matrox AVI Files into Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 22nd Mar 2009, 20:57 -
Using Matrox .avi files in Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 20th Mar 2009, 16:43 -
Import Matrox AVI files into Vegas Pro 8?
By SCDVD in forum EditingReplies: 2Last Post: 5th Mar 2009, 18:34
