I captured something on the best possible quality and it is too big to fit onto a DVD+R. It is about 4.57G, and I need to resize it to 4.3G or so to fit. I know I will lose a little quality but I need to do that in order to make it fit. I then need to make the large file inot .vob format, What tools can I use to do this? It is a .mpg file which I believe it MPEG2.
Can anyone please help me!!!
I would start by demultiplexing the file into raw video and audio stream. Use Tmpeg to do that. If your audio is a wav or pcm file you trancode that and you might save the 200MB's you ned to trim. If your capture card did the audio in one ot those uncompressed formats it will be large,probably 1GB by itself.
AviDemux Problem Joining Resized MP4
By thebigoc5 in forum EditingReplies: 0Last Post: 10th Aug 2010, 13:09 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 15:47 -
View\convert\edit *.mpg file (mpeg2) with an Imac
By drastus in forum MacReplies: 3Last Post: 8th Feb 2009, 17:58 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
