  1. Can somone please tell me what settings do I need to run VirtualDub s.t. I can extract the audio from a VCD ?
    Thanks in advance for any help.
    Australia
    Use TMPGEnc.
    Go file > MPEG Tools > Simple de-multiplex > select input file, output file > then hit start/begin/whatever
    It will output the audio as .mp2 to whatever location you specified.
  3. VCDcutter can do this, but virtualdub not. But VCDcutter is a demo and it can extract only 7 seconds of music (in MP3) with the unregistered version. If you want do this use vcdgear and after the tmgenc.
  4. Member Treebeard's Avatar
    Aug 2002
    Yes Virtualdub can as long as it is a mpeg1 file (VCD) and not an mpeg2 file.
  5. vcd is not the same thing of mpeg...a vcd has a dat file, that could be converted to mpeg, if you put the dat on virtualdub it won´t work...Only if you extract with a program like vcdgear...But the vcdcutter could make it directly...
