Does anyone know how to convert an SVCD into 1 working DivX file? I'm talking about big SVCD's such as 3-CD SVCDs and whatnot. I'm having a really hard time converting them over.
ooook, now, the video on an SVCD disk is placed in a DAT file in the folder MPEGAV. Copy that DAT from every disk to your hard disk
convert all those DATS into MPG's(use vcdgear for that: http://www.vcdgear.com/)
now you've got 3MPG's... Now we need to put them together, use TMPGEnc for that
FILE -> MPEG TOOLS
MERGE & CUT
-> ADD
-> Add the 3 MPG's you made.
Select an output
-> RUN
now you're made of your3 SVCD disks, 1 MPG file
Now in virtualdub.
Open the big MPG you made in TMPG
VIDEO -> COMPRESSION -> DIVX MPEG4 FAST MOTION (You need to have the DIVX codec installed... get NIMO CODEC PACK if you dont have it)
AUDIO-> FULL PROCESSING MODE
-> COMPRESSION -> MPEG LAYER 3-> 128kBit/s, 44100Hz 16Kb/S
-> OK
-> SAVE AS AVI
it'll take a while to finish, but when its done, you've got an AVI from about 600MbWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
It seems to me that this procedure is all for a regular VCD. The video on an SVCD is stored in the MPEG2 folder and saved as "AVSEQ01.MPG". I copy that over to my computer and multiplex it using TMPGEnc so I have a viewable mpeg2 file. But when I try to merge/convert with the rest of the cds, I have problems. I can never get a working one.
Any suggestions?
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 14:00 -
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 11:04 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30 -
Divx 2 DVD Problems
By KilinKind in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 09:03 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 01:26
