ok i burned an avi to cd so i would have room to convert it to MPEG well when i try to encode it with TMPGEnc it gets all the way to 60% then i get a stream writing error the video on the disk says MP3 but i burned it as a data disk so id have room on my hard drive and if any thing was to happen id have the cd to fall back on am i doing something wrong please help do i have to have any codes when encoding my pic of the movie is blurry i can barley see it thanx.
The reason why it probably stopped at 60% in TMPGEnc is because your file might have some bad frames in it. Bad frames can stop the encoding of a file. Use this guide to help you:
http://www.vcdhelp.com/forum/userguides/117930.php
Hope That Helps!!!
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 08:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 17:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 11:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 18:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28
