I'm sure this is an easy question to answer for some but I could not find the answer in my searches...
Basicly I reencoded a movie and the AC3 track but then realise I forgot the DTS audio track, which I did want.
So the question is how can I just rip out the the DTS track to a .dts file that I can import into Maestro with the .ac3 and .m2v file I already have?
Thanks.
Spudz
try VobEdit...Originally Posted by spudz2
Zzzzzzzzzz -
I figured I might be able to do it with that... Well I tried but it ain't workin'.
I loaded in the first .vob into VobEdit then clicked on the Demux button, then chose the .dts audio track radio button, then checked off Demux Complete Title Set. It then asked me where I wanted to put the .dts file and I could rename it or leave it as the default vts_xx_x.dts format.
After this is does it's thing for a while and goes through all the .vobs but afterwords .dts file is 0 bytes..
Any ideas?
Spudz -
have you try only one vob... not Complete Title Set? If that works then try to rip the dvd(main movie files) to one big file etc...
Zzzzzzzzz -
Adder78,
No, I hadn't tried to rip it from just the main .vob cause I figured if I did that I wouldn't get the whole stream, just part of it.. Unless the dts stream is only in the first .vob but I wouldn't think so....
However I will give that a try and let you know...
wizzy,
Yes it does...
Spudz -
Are you sure the movie has DTS track? Your hard drive has enough space? I'm using Vobedit quite ofter and never had a problem for DTS demux.
hcx3634,
Yep, I'm positive it has a DTS track. The movie in case you wanted to know is Road Trip Unrated Edition. Has 2 Ch AC3, 6 Ch AC3, and DTS.... I just want the 6ch AC3 and DTS tracks... I already have the 6 ch AC3 now I just want the DTS track.. And yes my HD has 20gb of space..
I suppose I could try another dvd with a DTS track maybe it's something strange with this title..
Do you use the exact same steps to rip a DTS track in Vobedit as I listed above?
Spudz
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
