i am having problems with the sony du 500a when i want to go from tape to disc i get the following error message - could not complete the last command because - no audio decoder available for this stream type.
can i do everything with Pinnicle Studio 8 - capture edit and burn to the DVD writer?
I only have Pinnacle Studio 7 - I hear 8 has improvements but the MPEG encoding in 7 was weak. I would render to a high quality AVI then encode with TMPGenc. Then you can author the DVD with the Sony software or Nero or Maybe Ulead DVD MovieFactory.
Panasonic DMR-ES45VS, keep those discs a burnin' -
You should be able to (I burn with Nero). I just recently finnished 77min home video with couple of menu (7000 kbit/sec, MPEG audio) and it looks good enough to me. TMPGenc might give you better quality, but I prefer using one tool for capturing, editing (cut, transitions, backround music, DVD menu) and authoring. Ony burn is step that I use Nero.
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52
