i was up to step 3 in sefys guide
http://www.vcdhelp.com/sefy/?id=encoding4.html
i played the file that dvd2avi had produced the first time round and it appears it stops before the film finnishes,its like it has missed out 9 chapters i have guestemated?
i also selected mpeg2 for out put SVCD.
So i have a file but not the full film? dam im confused.
do i have to start again or can i just do the last nine chapters from the film then merge it with the first chaptered i made.
dam i was close this time.![]()
so the guy punched me, and later i stole his parrot as way of revenge
Sounds rather strange, what did you do exactly ? did you worship the guide
or did you follow it and made changes according to your movie ? cause i'm
thinking maybe you even copied where I split the movie in the example.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
my bad dude it was my own silly fault.
THE SYSTEM IS PERFECT.
so the guy punched me, and later i stole his parrot as way of revenge -
Glad to hear it's working now
Best Regards,
Sefy Levy,
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
![Computer details: win xp
thalon 1800xp[true1500]
80gb IBM. 9Gbmaxtor:]
256sdram
hercules 64meg
whut?
soon
N/A
pioneer ??
N/A soon
N/A
KT3 ultra2
inbuilt soundcard on motherboard Comp](/images/buttons/computer.gif)
