YES I HAVE IT![]()
DVD-R/RW Writability Improvement![]()
DVD-R/RW Playability Improvement![]()
CD-R/RW Writability Improvement
CD-R/RW Playability Improvement
Surpport 2X writing on New Prodisc DVD-R Media
I will see first if my OEM writer can use it.
Then i must see how works the install under XP PRO.![]()
I ll finally test it.
I hope it the Christmas gift we all wait for !
Results 1 to 9 of 9
The source is Pioneer Japan.
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html
http://forum.firmware-flash.com/viewtopic.php?t=9533 is discussing it. -
Well install of firmware is quick and easy
I just burnt a Choice Branded 2X in 2X with InstantCD 6.5
Well again the "redondance cyclic errors" (some files not lisibles).
Hard to say if error comes from the DVD-R, i ll have other in 2 weeks (traxdata and Ritek).
Little thing that could be important : i did not do a reboot after firmware upgrade. Was it a bad idea? yes no?
Manufacturer : TDK
Code : TDKG02000000
Disc Type : DVD-R
Usage : General
Recording Layer : -
Recording Speed : 1 X - 2 X
Here are the info about my DVD-R. Those disks seems ok burnt in 1X. -
what - ?? flashing the firmware ? well it should work and does for most .. but when it comes to electronics _>> nothing is ever 100% fail safe ..
read the directions first on pioneers web site -- i can add that 1. dont if you have more than 1 hooked up at a time.
2. if mounted external , temp hook it to your ide to flash it .. works that way , not through firewire .. -
This seems to be RPC-2, so I guess you burn another life if you switch to RC1...
Samsung N510 to hit France this month
By usta in forum ComputerReplies: 1Last Post: 8th Jul 2009, 07:27 -
testing
By Baldrick in forum TestReplies: 0Last Post: 16th Jan 2009, 18:46 -
Testing
By Cirone in forum TestReplies: 0Last Post: 9th Jan 2008, 12:43 -
How do I get my Region 2 (from France) DVD player to work in US?
By squintycat in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2007, 23:00
