Hi,
I just found a (I think german) DVD->Divx program.
And I couldn't find anything about it on this forum.
It uses ffmpeg like ffmpegx, but it's much and much easier to use.
http://www.mh1.de/divxray
Take a look.
It's good if you just can't find the right settings in ffmpegx.
I'm willing to make a small "how to".
From OSEx all the way to the DIVX.
Mark
this sounds like just what i've been looking for.
i want to format my dvd into a standard avi divx file, and i think you can help. -
It's a ok program.
I successfully converted one DVD, but it failed on 2 others(after waiting 15-20
hours). It's good but needs some extra options. Like how large the end product will be? The 1 Divx I made was great quality, but only fit on 2 CD-Rs.
I hope there will be revisions on the program.
