I have extracted wav from avi file with virtualdub and i cannot load this wav/edit in any wav editing software!
any other software can extract wav from avi?
If "Direct Stream Copy" was activated in the Audio menu of VDub, you don't get WAV but MP3 or whatever codec is used in your AVI. Choose "Full Processing Mode" and set compresion to "No Compression(PCM)" before saving to WAV.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
thanks for the reply...well its AC3 sound and it wont let me do it your way....
Try this VDub version, it can extract AC3 sound in Direct Stream Copy mode. You can convert the AC3 file to WAV with Azid (I think you have to to use Ac3Fix first because VDub always writes a WAV header).
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 05:59 -
AVI to WAV in Virtualdub
By crumbworks in forum Video ConversionReplies: 20Last Post: 9th May 2008, 04:10 -
KMPlayer, and use VirtualDub to edit AVI file, warning shows up
By rozaback in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2008, 20:35 -
Extracted WAV doesn't fit to original video!
By GangstaRap in forum Video ConversionReplies: 24Last Post: 15th Jan 2008, 19:24
