ok i used the kvcd templat 528x480 ntsc... to make a film but the thing when i converted it and put it inside my dvd player doesn't want to play fullscreen or at least a little bit full screen... it plays in the center but to the left side.... it didn't expand
You probably have to change the resolution from 528x480 to 544x480. Some players don't like 528x but play fine at 544x. Give that a try
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
how about if i used 480 x 480 .... the original file is 608x256
umm which one of the KVCD templates is best to use,....
the reason why i used the 528x480 was becasue someone said that those are the only ones u use or something like that -
You've got more of a chance of the picture turning out properly if you don't use a wacky framesize for an X/S/VCD.
The common framesizes used are:
352x240/288
352x480/576
480x480/576
704x480/576
720x480/576
Regards.Michael Tam
w: Morsels of Evidence
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 16:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 07:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 16:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 12:08 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 21:05
