hi ive ripped a dvd with smartripper
then tried to framesave with dvd2avi i followed the instructions
but i have the l\atest version of dvd2avi and cannot find the setting for mp3 compress but run the prog anyway no ac3 file when finnished please help
i have the m2v file
when you frameserve w/ dvd2avi, you will create a .d2v project file and a .wav audio file. i don't think dvd2avi will produce any mp3's.
in the audio dropdown menu, make sure you choose track 1. then set dolby digital to decode. once you do that, you will have a .wav file. if not, then you need to set to track 2 and try again.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
